WTT: Bi-posto Subframe for Monoposto Subframe
1205 Views 13 Replies 0 Participants Last post by  Guest
I've got a Bi-posto subframe from a 2000 748 in mint condition that I would like to trade for a Mono subframe. If anyone is interested, lemme know!
Thanks!
See less See more
1 - 14 of 14 Posts
Re: WTT: Bi-posto Subframe for Monoposto Subframe (Holiday)
TTT...
you got mail.
Re: WTT: Bi-posto Subframe for Monoposto Subframe (ducatilover)
wow, can't believe someone bit on this one. eh... I have one too. seriously. Anybody want to trade me my bi-posto sub for a mono?
-ian
Re: WTT: Bi-posto Subframe for Monoposto Subframe (ians)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ians »</TD></TR><TR><TD CLASS="quote">wow, can't believe someone bit on this one. eh... I have one too. seriously.
-ian</TD></TR></TABLE>
Try getting your own thread. seriously.
See less See more
Can I run a mono subframe with a biposto seat? Will it hold the weight?
Holiday, I apologize. My post was in bad form. Thank you for bringing that fact to my attention.
-Ian
Re: (ducatilover)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ducatilover »</TD></TR><TR><TD CLASS="quote">Can I run a mono subframe with a biposto seat? Will it hold the weight?</TD></TR></TABLE>
In regards to a 749/999 (don't know about the others)...
The weight of the seat? Sure
The weight of a person on the seat.... nope.
Plus, mono subframe has no attachment for passenger pegs, and is a lot shorter. The Bi subframe is so long it sticks out from under the mono tail. The Bi tail needs to attach right behind the seat to the Bi subframe - the mono subframe does not have these attachment points as it is much shorter.
I could take pictures and post iffin you want.
I just got a mono tail on ebay and found it won't fit on my Bi subframe without cutting the subframe. So I'm getting a mono subframe and keeping both so I can switch from mono to bi as my needs / mood dictates.....
trev
Modified by mastermind at 11:41 PM 7/22/2005
See less See more
Re: (mastermind)
Trevor- My 748 monoposto, as well as many other mono's, came with a biposto subframe. Don't know why you had trouble fitting your mono tail on a bi-posto subframe- was it a stock tail that you bought, or an aftermarket?
Ian- No prob.
Marco- I'm going to take the subframe off tommorow (Sat.), so please let me know. I'll throw in some cash too to sweeten the deal.
Ross
See less See more
I might be wrong, I may already have a biposto subframe
It seems like I may have a biposto sub frame as well (just like you described yours) I looked at it and it has the holes for the passanger pegs. Does that mean I have the biposto subframe already?
Please advise?
Mine looks just like this:
http://cgi.ebay.com/ebaymotors...=WDVW
Re: I might be wrong, I may already have a biposto subframe (ducatilover)
Biposto subframe = steel+mounts for passenger pegs, mono = Al, no pass. mounts.
also has different plate for seat latch (surprisingly only $11), spaders, screws.
going from bi to mono requires new mounting of ECU (cable length different), this took me a while to figure out how to cleanly mount and get to fit, inner fender different (different mount points), tool tray not the same.
I know as I converted '00 996 to mono
Re: I might be wrong, I may already have a biposto subframe (CharlieP)
Marco- you're in the same boat; Monoposto bike with a biposto subframe.
Looks like I'm going to buy a mono subframe instead. Anyone want to buy a Biposto subframe in great condition?
thanks Holiday! If I would have known I had a biposto I wouldnt have wasted your time. At least now I know what I got. I saw a mono subframe on ebay. Check there.
Thanks for the info Holiday!
Re: (ducatilover)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ducatilover »</TD></TR><TR><TD CLASS="quote">thanks Holiday! If I would have known I had a biposto I wouldnt have wasted your time. At least now I know what I got. I saw a mono subframe on ebay. Check there.
Thanks for the info Holiday!</TD></TR></TABLE>
No prob!
1 - 14 of 14 Posts
