Re: (team-red)
SB2000 was asking about snowflake rotors, then talking about changing forks and calipers and rotors. I think someone is confused about something.......maybe it's me. I didn't think SB2000 was looking to use narrow band rotors, I think he's just looking for some stock rotors with the 'snowflake' carrier pattern. I don't think the rotors pictured are narrow band rotors.....the rotor looks to be the same width as any other rotor. The rotors pictured came stock on some 998's and should work on any year 916. Narrow band rotors are expensive and require the correct calipers, also expensive. The rotor is offset farther from the wheel as well, and I don't know of an adapter that mounts the caliper further out on the fork leg. If there is I'd like to know. As far as I know they only came on the 996R and 998R (I may be wrong). At any rate, if SB2000 wants to use the later calipers with the 65mm hole spacing on his '97 916 forks, he'll need some adapters like the ones I have for sale.
Modified by TS at 4:56 PM 7/26/2005
