LED Tail Lights!
K! H-RC51
Hotbodies tells You to Use a Heat Gun to Remove the Silicone from their Lights! In the Instructions for Removal/Replacemet!
Remove all of the Silicone from the Tail Light with the Heat Gun & what's left of the Residue with Goo-B-Gone! Don't Forget to Use Vinegar to Neutralize the Acetate from the Goo-B-Gone on the Tail!
Very Important!
The HB's sit into the Tail Housing Flushed & Held into Place By the Silicone Only! Once You Remove it This is What You Can Do;
1st & Foremost, after Cleaning Out the Tail Lights of it's Lights & the Silicone, Mark the Outer Circumference of the Openings of the Tail Lights withe the Cardinal Points/Clock 12-3-6-9-O-Clock to Center LED Lights! Use Carpenters pencil or Wax Pen so You can Remove the Marks Easily! You can also do This Before You Remove the Lights as Well
1: Use an Exacto Knife to Remove Clear Lens & Gutted. Put Universal Round LED Cluster Light On Front Plate ( Remember to Mark 4-Clock Points on the LED's As Well) with Light Amount of Silicon. Light Pressure Checking Marks & Let Set Over Night to Dry!
*Do this with the Lights ON! Check Periodically during the Install that the LED's Are Even & Aligned! You Might Need Sun Glasses! Seriously! If You Really Want to Go Blind, Do this Project @ Night!
2: Use Cut Outs from PVC Connector Pipes with their Gaskets to fit Into the Openings of the Tail Lights! This Procedure Requires a Little Bit More Elbow Grease! This "1" is for You Ingenuitive Bad A$$'s
Hope this Helps!
