Re: (Tykester)
If I could, I'd get an FE due to the incremental changes it has - especially the 3-phase 520W alternator, transmission ratio with "hunting tooth" (32/59 instead of 31/62), slighly revised headers for a little better ground clearance, internal oil lines in the heads, deeper heat sinks, and all the little things - like the reversed orientation of the starter solenoid so you can check the electrical connections alot easier and such. Then put the silver bodywork away and get some cheap OEM's or sharkskinz do the monoposto to biposto mod:
If you like a red biposto, it's just as easy to do - here's mine (although I prefer the older, fairings without the vents):
