1 - 3 of 3 Posts
I installed my front and rear turn signals tonight. I put on LP short stalk three wire lights in front so i could keep them as marker lights, On the rear I put Shock Racing LED two wire lights. Everything lights up fine and signals work both front and rear but the turn signal indicator light on dash stays on now and the rear turn signals stay on like marker lights but work fine as turn signals so really they now function just like the front ones. Any help would be great. Thanks Rick
Sounds like you have current going back thru the curcuit that is off..eg:running lights sending current to the blinker curcuit. Did you hook both front lights the same? Also is the front lights Dual filament? If not you wil need diodes in the curcuit.
1 - 3 of 3 Posts
