41 - 59 of 59 Posts
Can you post some pictures please? I'd like to see what you're talking about.
I considered doing something like that but thought the passenger seat structure would be wobbly with a case attached due to freeplay in the rear lock latch.
I'll send you some pix and please post it up for me. I'd said. I've been using this for years. Made it to Canada and back. Mexico D.F. and back without a hitch.
Though, your concerns are very valid. I also have a bungee cord just in case.
Since I am at it..I'll show you guys the other Tai Mod:D
Who can post pictures for me..I'm too stupid and lazy for photoisland..damm I hate them.
Moderator
Discussion Starter #43
Did you powder coat the clutch cover?
No sir,
That would be high temp, chemical resistant and chip resistant paint. Second cover I've done with zero issues.
Not quite as tough as powder coat, but it does the job just fine.
Have my RC apart again this winter. Mainly to fix the slipping out of gear trans problem. Doing a few other things while I have the cases apart too.
I'll throw up some pics later.
Mine is back apart...
CBR coil mod being done and changing plugs. Color is still looking good on the old ones and my bike has 38k on her.
Also installing new 6K HID's with slim ballasts to replace my one bad one and the monster Ballasts that I had previously.
I've always wondered how different the heli-bars are than something like the stock bars on a cbr which rise up from the clamping surface (opposite of what the RC bars do)
From the pictures that I've seen of the heli-bars, they are pretty much the same thing. I have a set of cbr1000 bars that I was running, and pulled off when I put the sato clip ons on. It would be interesting to take some measurements and compare them against the heli-bars. If you have them handy, please post up a few pictures.
I was never able to get the cbr's up high enough to touch the underside of the triple without the clutch master reservoir hitting the upper fairing. I think that is pretty much the limiting factor in all risers for the RC, unless you are willing to cut the upper.
Finally got around to taking pics of the heli bars....
Mine just rebuilding it & cost me near 5K(Singapore dollar)..
So new project....
I blew a fork seal out this weekend. This is on a set of Freshly rebuilt forks by 2K Motorsports Richfield MN. I will have replaced both Fork seals now in less than 2500 miles of the rebuild. The Honda stealership told me they had been assembled wrong and not bled properly causing them to pressurize the seal too much.
So new project....
What exactly was wrong about them?
They weren't bled properly and are pressurizing the are above the seals. causing the fork oil to puke out even when the fork is off the bike. The tech that disassembled them said when he unscrewed the cap it shot towards the ceiling and he had to catch it. (going on what he said. I am going to ask to watch them take them apart this time.
Moderator
Discussion Starter #52 (Edited)
More progress
Here is some more progress I my current crf450r supermoto and RC51 builds.
Snorkel installed (thank you Ben at rc51parts.com)
Simon Kobe Brembo mircoswitch:
Factory Pro EVO shift star (not really much to see :D ) also painted water pump cover and installed it. That red oil cap is from a crf450r (direct fit so why not?)
Moderator
Discussion Starter #53
cbr coil mod and motion pro quick disconnect fuel fittings:
Electronics moved to battery box also installed MOTY design a123 battery (not pictured, thank you Brian), also have prototype toolless seat removal bolts and thumbnuts that I may sell in the future (all stainless hardware):
More stuff moved:
I'm currently modifying a fiberglass solo tail (Thank You Ben from rc51parts.com) and making a new undertail, I'm also awaiting a carbon parts big piston clutch slave (Thank You Mark)
Moderator
Discussion Starter #54
crf450r silicone radiator hoses installed also installed Trail Tech water temp sensor:
Brembo relocation bracket awaiting 4pot Brembo 40mm caliper (currently being modified to fit):
Trail Tech supermoto kickstand and fastway stainless foot pegs:
Trail Tech Vapor:
Boyesen clutch cover (why not it was cheap):
Going back to street trim...
Back during the change over...
Mod list...
3M Clear Bra Film in assorted places
AFAM / DID 520 Conversion 15/41
Ahlman Speedo Recalibrator
Aluminum Rear spacers
Assorted Titanium Hardware
Billet mirror block off plates
Brembo RCS Radial Brake M/C
CBR600RR Coils with modded harness
CRG LS Mirrors
Current Tires – Dunlop Sportmax Q2 (120/70 & 190/55ZR-17)
Dan Kyle gold Shock link
Dynojet PCIIIR with modded Kyle map
Greggs Customs LED flush mount turn signals
Hi Flow Spal Pusher Fans with custom brackets
Billet Clutch Slave
HRC Fuel Tank Hinge Pin Kit
Late Model Instrument Cluster Cover
Lightened Rear Caliper Hanger
Lightened rear rotor
LSL Clip-ons
Magical Racing Carbon Rear Hugger
Moriwaki MTM rear-sets with custom rear brake M/C
Motovation Universal Fit Bar End Weights with Sliders
MRA Windscreen
My 2003 RC51,
Nicky Mod
Ohlins R/T Forks with Superbike internals
Ohlins Rear Shock w/ Ti Spring and Motion Pro alignment ring
PAIR Mod
Phillips European Headlight Bulbs
Sato Banzai Carbon exhaust
Sato Swingarm spools
Sato Ti side-stand
Scotts Dampener
Side-stand switch mod(soldered harness)
Spiegler Brake and Clutch lines
STOMPGRIP Traction Pads
Swing arm paint strip
Tail light/signal integrator(soldered harness)
Thorsten Slider Kit
Tridon EP37 LED flasher
Turn One Carbon Snorkel
Vesrah RJL Racing Brake Pads
Yuasa YTZ7S Battery
Doughnut.... Are you gonna street your 450? The only reason you would regret it would be the points accrued on your license...
Moderator
Discussion Starter #57
Oh yeah :D
I still have to do all the wiring and get a battery for her. I just really busy right now. I'm closer to having the 51 finished, so she's first so I can get riding again.
I'm almost done though. I'm having some issues with the rear wheel / chain clearance, I'm sure you know what I'm talking about.
BTW, Did you offset your rear wheel when you tarded your crf?
mine was Tarded when i bought it. But yes my rear wheel was offset. it doesn't take too much to offset it to get the clearance.
Mine was streeted but I didn't run a battery at all. I just ran the lights power off the stator. so the lights were only on when she was running. and i also had a hidden switch to power the ignition(no Key) and i used a Disc brake lock whenever i parked it. I also never road it anywhere that I was worried it would sit for too long unattended. 450's are light enough 2 guys(or one big ass Mofo) can pick it up and load it into a truck.
Moderator
Discussion Starter #59
I love how light it is. It's so easy to move the bike around my garage. I can almost bike it up alone. I remember when I first got it and it was in the back of my pickup instead of a ramp, a friend and I just basically picked it up and rolled kinda rolled it out of the truck.
Can't say the same for my piggy LOL.
I guess I'll just have to offset the rear a little.
41 - 59 of 59 Posts
