Hey all I'm hoping someone could shed so light on a problem i'm having with my Sp1.I've recently had a problem with contaminated fuel fouling my plugs.So I've cleaned my tank and serviced my bike incl checking the valve clearances.
Last week while on the way to work it dropped onto one cylinder.The front had stopped firing.I might add that while riding the night before i got drenched in a storm.I limped back home and locked her up.
After changing the fouled plug it still wouldn't fire,no spark.
So I suspected a faulty coil.
I swapped them around and she hesitated but then fired up on both cylinders...weird!
It blew a fair bit of white smoke out of the left end can which I assumed was un-burnt fuel in the pipes.It also has a exhaust leak which I've just noticed.
The bike idles fine now and revs as normal,but when I crank the throttle white smoke come out the left exhaust can.
Has anyone has a similar issue? Can any help me out?
Cheers
James
Cheers
James
