·Guest
Removed the pressure plate and springs to paint the pressure plate on my ST4. In replacing the spring bolts I didn't use a torque wrench but cranked them down pretty damn tight. Starts and idles in N fine but squeezing the clutch lever doesn't do anything -
do I need to bleed the system after removing the plate (and rod)?
When in N idling everything appears and sounds as prior to removal.
Thx.
Thx.
