1 - 20 of 156 Posts
Full Spectrum
Ok guys, here is probably the most cost effective way to lose 5-10 lbs from your RC. Speedcell battery-
I ran this battery all last season and never had a problem.
Here is a link to a discussion which has all the information you could want.
I sell these as I am THE distributor. As such, I am always available to answer questions, but really that shouldnt be needed after reading the linked thread.
Feel free to contact me regarding pricing and availability.
[email protected]
Jason
250! Good god man! Whats in them things diamonds?:woot:
Kidding around but I am sure they have their uses....just not for me.
Full Spectrum
Discussion Starter #3
What other motorcycle part gives you a 10 pound weight savings for $250?
What other motorcycle part gives you a 10 pound weight savings for $500?
Let me know so I can go buy it.
Dunno, just saying its a BATTERY. I could not justify spending 250 on a EXPENDABLE part besides a set of tires. Now if this battery would last forever then I would be all over it.
Purveyor of immaturity
Jason. What do u think about adding this to my laundry list of mods u have been doing to my bike? Good mod for street in ur opinion??
Phill
Point taken here :rolleyes:
I'll tell you what...the day my 4 lb relocated unit even starts to fail I'll hit you-up:clapper
$125.00/lb. is still a good deal.
Full Spectrum
Discussion Starter #7
Got it.
And thats why I linked to the thread discussing this.
This isnt exactly a wear item.
It will last as long as your motorcycle. Period.
Go read the linked thread.
Jason ive been eyeing this mod for a while now and have been lagging in asking Josh this question but maybe you can answer it for me. Can a stock RC use the smaller super sport battery? Or since its a twin with a higher compression than I4s will it need the superbike one?
Also i see that on the link Josh said that the highest temp these batts can see is around 120 degrees? I relocated the small yuasa batt with the thorsten relocator that now sits under the motor, will this battery survive under there with all that heat?
Full Spectrum
Discussion Starter #11
No, I would not recommend that you use the Supersport battery.
I ran the Superbike all last season in the front just as you do, and never had a problem. It will certainly survive.
Guys- you can PM me for payment information.
waterproofing
what if it gets wet? - say you get stuck in a downpour or just riding in the rain. i see you're working on a sealed version too but what about the current ones? will it be okay if its mounted under seat/stock location and ridden in the rain? obviously, more of a concern under motor/ front header in the wet?
thanks
Full Spectrum
Discussion Starter #13
thanks
Ive never had a problem, and I raced in the rain. As I said, I had mine right behind the front tire. Under the seat it will likely not see any water at all.
We have never seen a problem with wet weather riding with the current version of this battery- on any bike.
You would probably have to submerge the battery to have an issue, but then you also have bigger problems to worry about.
Full Spectrum
Discussion Starter #15
I am guessing these would also work better in a " total loss " system , as they don't mind been discharged ...
We sell a larger battery for use in total loss systems. And you are correct about their ability to be discharged and recharged. You can charge one from fully discharged in about 10 minutes.
These batteries work great in standard charging systems.
the nicest feature of such a small battery or a relocated battery, is being able to relocate all the crap in the tail section to under the seat...easier access with race plastic,
also less chance of destroying your ecu in the event of a bad highside that takes out the tail..... speaking from experience unfortunately, not on the RC thankfully.
Banned
If these things do everything you've said they will then I'm definately getting one. Just gotta pay my property taxes first :woot:
Full Spectrum
Discussion Starter #19
Yeah, there is a ton of very detailed technical information being discussed on various forums, and if you are interested in engineering it might be a fun read.
Myself, I am more interested in stuff that works. The engineering talk obscures the inportant information- missing the forest for the trees imo.
These things work for sure. Before I agreed to distribute these batteries, I spent a full race season testing them on my racebikes in all kinds of conditions and had ZERO issues. I cant say the same about too many other parts frankly. :)
These will be on display at the DC area motorcycle show this weekend in the Ducati booth. Speak with Donnie Unger if you are curious and are at the show.
Maybe I missed it but one thing I see is this: - Cycle Life (DoD spec) = 1,000 cycles. What does this mean for us? 1,000 starts? 1,000 times you can completely discharge? 1,000 charges? Now the other concern depending on that is constant draw/charge. While riding there is constant charging and discharging so how long can the battery stand up to that? I see that its been tested with a bike but from what I saw not for anything too terriblly long IE 5-10 years so though it does say 1% discharge over 1 year for not moving/getting started whats the discharge rate for full use? Everything that holds power like this has a life so whats this one? I would find it hard to believe that it will last forever...5, 10, 20, 50 years or what? See, you peaked my interest so now I got to ask all of them questions.
1 - 20 of 156 Posts
