1 - 3 of 3 Posts
Hey guys wondering if someone can help me out?
I lost the bolt that connects the rear brake pedal to the rear master cylinder.
Installed a bolt but it binds the two pieces, fiddled with the bolt freed up the binding but now it has way too much slop between the pedal attachment point and the actual hole where the bolt goes through.
I was hoping someone could post up pics of the proper bolt with a measurements of the the length of the shank. Is there a portion of the bolt that has no thread? Is there a bushing or washers missing?
All pics and measurements will be really appreciated...The circled portion is what I am trying to explain.
Sorry for the large crappy cell pic...
Apologies for the late reply on this (and I won't be much help I'm afraid) - was away on vacation.
I'd suggest some loctite - and a flat washer behind the bolt head. If the bolt is too sloppy in the hole on the lever - you'll need a bushing or sleeve.
Unfortunately, I do not have any spares of the bit you're looking for.
WW
Discussion Starter #3
No worries got it sorted out...the correct "length" bolt allows the outer piece to rotate independent of the inner piece.
Thanks the rearsets are working out fine nice positioning...
1 - 3 of 3 Posts
