Tom,All I know for shure is I wish I had the time and parts lst night to do this mod right...stacking aftermarket parts on top of each other takes a lot of patience my master res is too tall so I screwed it directly to the cylinder( I am limited to clip on heigth so thet are down the tube even further than befere) and had to move the gauge foreward and drill new holes in my gen1 snorkel (after dark at tis point) the pro tek top clamp bolt heads want to be at the same place as the cycle cat riser and I need to take it all apart to add magura or brembo so I can go remote with both resivours
Other than that final adjustment will take a week
In the end it will get sorted![]()
What I had done with these is to make additional brackets for the reservoirs and mount them using the bolts that hold the top triple clamp on. Here is a pic where you can see where I mounted the reservoir. I can take some better shots tonight. You can also see where on the fork tubes I had them mounted. I also messed around with the bar angle in order to clear the fairing and gauges. You can find a sweet spot where everything comes together.
http://webpages.charter.net/seaton001/DSC_2826.JPG
Scott
