AEM SSSA Titanium Cush Drives-5 pack
These cush lugs have been designed and manufactured using the best-known materials and processes for the application. Specifically, these cush lugs were designed to prevent the inner lug or outer ring from separating and backing out of the rear cush/sprocket assembly. This is a common occurrence with the stock steel cush lugs and usually results in significant damage to the swingarm eccentric adjuster. The design of this lug will eliminate any displacement of the inner lug or outer ring - even if the elastomer de-bonds from the inner lug (the problem with the stock unit) or outer ring.
AEM Titanium Cush Drive Bushings are a direct replacement for the OE bushings for all single sided Ducatis.
The OEM rubber is replaced with a more durable urethane that slides in from the outside and is retained by a ridge on the inside.
Designed for safety wire.
Saves .5lb over OEM cush drives
Modular design allows the urethane cush drive to be replaced seperately.
Set of 5 fits Ducati 748-998/ S2R/S4RS/ MTS1000/HM/Mhe/M1100/848.
Set of 6 fits Ducati 1098/1198/Streetfighter/ MTS12/Diavel
