THERMO-TEC Exhaust Insulating Wrap: Copper 2"
Was:$57.10
Sale:$54.25
2" X 1/16" X 50' exhaust heat insulation wrap.Generation II Copper Header Wrap improves heat resistance up to 30% more than current technology, by utilizing a new proprietary coating developed by Thermo-Tec; improved Thermal-Conduction-Technology (T-C-T).Generation II Copper Exhaust Wrap creates more horsepower and reduces under-hood temperatures, increases exhaust scavenging, withstands continuous heat up to 2000ºF, contains no asbestos. Thermo-Tec exhaust wrap will not over-insulate a system when properly installed due to a proprietary coating developed by Thermo-Tec - Thermal Conduction Technology (TCT) - that conducts heat across the wrap's surface. This coating controls heat build-up and dissipation. Generation II Copper Exhaust Wrap is sold in 50 foot rolls with a low profile 1/16" thickness.Perfect for bikes with belly pans, or bikes with underseat exhaust systems that radiat heat on the rider. One roll contains enough to wrap most 2 cylinder bikes
THERMO-TEC High Heat Wrap Coating: Black
Price: $10.58
Sale: $10.05
To finish off a clean and well-protected Exhaust Insulating Wrap application it is recommended to use the Hi-Heat Coating. The coating will protect the wrap from abrasion and harmful liquid spills. Extra resins and binders toughen the surface, extend the life of wrap by protecting it from friction, and seal the pores to minimize the penetration of harmful liquids. The coating also works excellent as a hi temp paint directy on metal surfaces
