1 - 5 of 5 Posts
I've read a ton of posts and none of them list everything that is needed to convert a 00 to a 02+ swing arm. What all would I need other than the swing arm and longer chain to put a 03 swingarm on my 00 RC?
Discussion Starter #2
Re: Swing arm conversion help... (HanZcap)
You need a : sleeve; 02+ pivot bolt and nut; and 02+ castle style nuts. And if you run the same brake caliper, you'll new the 02+ caliper mount (bracket)
Discussion Starter #3
Re: Swing arm conversion help... (Motorcitysuperbike.com)
OK so from what I've learned/read you need a special sleeve for the swingarm to work. Does anyone manufacture these sleeves? I'm suprised nobody sells conversion kit minus the swingarm.
Discussion Starter #5
I sent him an email and IM to see if he still has it.
1 - 5 of 5 Posts
