I just finished replacing clutch plates/springs and when tightening the crankcase cover bolts I stripped a couple. They just kept turning!
I was easily able remove all the bolts but some are visibly twisted/stretched.
I can't see any thread damage to the crankcase bores.
I was using a torque wrench but I think the rubber oil seal was throwing it off because set at 7.5 ft/lbs it didn't click.
Is it possible just the bolts are damaged? Are these bolts be softer then the aluminum crankcase?
Does it seem reasonable to just replace these bolts with fresh allen bolts/blue lock-tite and hand torque?
Thanks once again guys!
T
T
