1 - 6 of 6 Posts
I just installed Kyle preload adjusters on my bike. Problem is I can't seem to turn the adjusters (clockwise or counter)
Is there something wrong with my forks? What could be the problem?
Thanks
Re: Spring preload adjuster problem? (RicardoA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RicardoA »</TD></TR><TR><TD CLASS="quote">I just installed Kyle preload adjusters on my bike. Problem is I can't seem to turn the adjusters (clockwise or counter)
Thanks</TD></TR></TABLE>
Nothing wrong with the forks. They are just hard to turn with the adjusters. The adjusters are just for bling IMO.
I don't have any problems turning mine. Maybe you need to get on the Jose Canseco workout regiment.
Re: Spring preload adjuster problem? (SpeedKills)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedKills »</TD></TR><TR><TD CLASS="quote">I don't have any problems turning mine. Maybe you need to get on the Jose Canseco workout regiment.
Very true. Mine were impossible to turn right away. But the do turn, it just takes a lot of muscle the first time you adjust. After that it should be easy enough.
If you have a front stand that lifts from under the triple trees or any other way of taking weight off the front end you will be able to turn the adjusters easier.
1 - 6 of 6 Posts
