·Guest
Now that the duc is up on the stand for the winter, getting ready to do a little maintenance. I heard you should change brake and clutch fluid every so often so I plan on doing that next.
1. Can anyone recommend a decent brake/clutch fluid? Any benefits to using the racing stuff...does it really matter? Anyone ever use Royal Purple?
2. Can I flush the hydraulics by just adding brake fluid until clean stuff comes out? Do I need to drain and flush with something else?
3. Kevlar lines. I've heard they stretch over time. True? Any benefit over SS lines?
Thanks to anyone with input!
