1 - 14 of 14 Posts
Hi Guy's,i got my 02 sp1 in feb this year with 8000 miles on the clock it had no power commander, standard 16 tooth front sproket.It now has the commander on with a 15 sproket and has now done 11500 miles....The problem i am getting to is that it sounds like the clutch mabe slipping,Any ideas how long they are suposed to last ?
What kind of sounds are you getting? Also the life of the clutch depends on how you treat it. I would think that if you change your oil regulary and don't clutch the front wheel up everwhere you ride that it should last longer than 12k miles. You may have glazed the plates which happened to my SV before I had purchased it. When the motor and clutch was cold it would "Chatter" some times until it got warm. My SV only had 2k miles on it at that time and now I have close to 15k and she still rides like a champ and no problems with the clutch this far.
Discussion Starter #3
there is no clattering noise ,no wheelies off the clutch,oil gets changed regulary,the only noise i am getting is when i open her up hard it just sounds like its slipping,(it could just be my hearing giving me s**t or old age)the clutch also only bites when the leaver is nearly right out....
1st Off 2002 RC51
Is a SP2!
2nd, I don't understand HOW anyone could NOT know when their clutch IS slipping or NOT
:wtf You have a "tach" on that MC don't you!....??? Here's the answer to your question, next ride when you know about where you think you have the problem, just before look at your Tach, then hit the gas, if your tach readings
RPM's start jumping up faster then you are accelerating, well then your clutch is slipping, if not it's not.
I Hope This Helps....
Peace Jeff
Discussion Starter #5
Hi Jeff,i will give it a try thanks
Discussion Starter #7
because thats what it is:banghead
carlo's sp1 said:
...i got my 02 sp1....
Contradictory statement.
2002 RC51 is an SP-2 (at least in North America. You guys ride on the wrong side of the road so it may be different there. :woot: )
Discussion Starter #9
you are correct 2002 would be an sp-2 over here to but this sp-1 was registered in 2002,not by me but the guy i got it from
Only 12k Hell I have 93,000 miles on my Stock clutch from commuting, I dont do too many wheelies and I have had all secheduled services done. My shit doesnt slip at all.
+1 on the moly in the oil.. it will build up on the clutch plates and cause it to slip.
bafflebrain said:
First of all, what oil did you use last?
I would not rule out you using car oil with friction modifier.
It might be your clutch, though. I had a 2000 RC that I turned into a track bike and the previous owner ragged the hell out of it. I am assuming terrible wheelies & starting methods. Several of the clutch plates were broken. You can look at all your clutch plates w/o draining your oil. Just put it on the sidestand and pull the clutch cover. The oil level is well below the bottom of that cover. If you do have broken plates, then you know you have to change your oil anyway.
Discussion Starter #14
the last oil change was with a honda dealer when it was serviced in september ....I assume he would know what oil to use:confused:
1 - 14 of 14 Posts
