·From the word “GO”, my slipper clutch has been making my butt pucker with all its weird idiosyncracies. I think I have found the culprit.
The bearings are too large to fit in the grooves of the lower portion of the hub. It’s not something I noticed until today because during assembly, you hold them in place at the base of the groove with grease.... I couldn’t see the miss fit. But, as you can sorta' see in this pic, they don’t set down in the groove as they go up the ramp. I wedged them in place for the pic.
They fit fine in the grooves of the upper section of the hub.
If you can remember, this is where they ended up the first time they jumped ship.
The thing would work fine for a while and then go into a full blow epileptic seizure. It left me stranded today. That’s when I did some in-depth detective work. I think with the over sized bearing, it would work alright while the grease was plentiful and then bind up once things thinned out a bit.
Also, I don’t understand why it was designed so that it could ramp up so high that the bearings could come out of their respective ramp grooves.
I’ll try to find some bearing that are a pube-hair smaller on Monday.
Anyone have any other theories?
