1 - 20 of 25 Posts
I have been steadily thinking about a way to get more grip on my bike. I managed to accidentally get some Honda Polish on the seat a month or so ago, and the seat is slick as shit now. I have tried cleaning it a couple times with no luck. I am beginning to think I got some on the ass of my leathers that needs to be clean.
I already have stomp grip, but its location reduces its usefullness. It seems if the seat was more "grippy" it would be a fantastic improvement. Does anyone know of a product that could be applied to the seat to improve traction? Does the Sergant/Corbin offer more traction? What about the foam pads?
Munky
Use some lexol leather cleaner. It will make it alittle more tacky. You are supposed to use the conditioner right after but skip it for a more tacky surface.
Replace
E bay.The same thing happened to my 77 xt 500 except my boss at the time was the one that shined the seat up "real nice" for me. :wtf
I got a different one,after trying everything to get that slippery crap off. :banghead :twocents
Discussion Starter #7
Its already been ~3 rides, even a good 4hr ride in the rain in North Carolina. I have used simple green with no love.
Its to the point I have learned to use other contact points on the high side of the bike. I guess that its been a good learning experience, but its getting old.
Next Strongest Stuff, Deep Purple or Power Purple! WD40 To Cut Into The Polish 1st!
OK, try the "Deep Purple" or "Power Purple" as this stuff is STRONGER than the 'Simple Green", just DON"T let the D/P or P/P get on any bare alu.! You most likely already know that though
, just let it sit and work it into the seat alittle, see if that doesn't help. I'm sure this WILL do the trick.... You might want to try WD40 1st, this will cut into the polish, then D/P or P/P..... That's GOT to do it!
Peace Jeff
Discussion Starter #11
Thanks for the info guys, I will try some of the other stuff first, if not...new seat time.
Capt. Home Slice said:
Hmm.
I've oversprayed Honda Polish on my 996 seat many times and it wears right off. Perhaps the seat cover is made of different material?
I dont know what it is. I have been down this road before, and it always wore off. Maybe its the combo of new A* leathers and the seat...I dont know whats going on, but it gets old sliding all over the seat.
P/P & D/P
Bump<>
Just wondering, what is going on, have you got this takin' care of?
What did you use to fix the problem?
Power Purple? Deep Purple?
These are 2 that I think WOULD take care of the problem...
Peace Jeff
Also you should try some rubbing alchohol after you use the purple stuff! If I were you I would remove the seat while using the purple stuff just to be on the safe side! Good luck!:)
If its been 3 rides and a 4 hour with rain, you didnt 'just get cleaner overspray' on it. It must have been saturated on the seat....
Heres a tip.....dont use it on your tires.
Discussion Starter #16
Havent even been out to check on the bike since I posted this. Sorry, but when I do I will update.
Hey, thanks for being a dick!
I didnt spray honda polish on the seat...what I may have done was use the rag I was using on the bike to wipe off the overspray.
I am not sure it is the Honda Polish. Because honda polish over spray does usually wears off after a few minutes of a ride. I think it may be fancy new A* leathers casuing the problem. I am going to give them a good degreasing and see how it goes.
Discussion Starter #17
macchiato said:
if you are really hanging off the RC, this stuff is all but worthless if installed in manufacture suggested location. It really should be in the crotch area (uncomfortable) and a horizontal strip along the tank near the Honda decal for the forarm. But it does give it that race-esque quality. If I had it to do over agian, I wouldnt buy stomp grip...or I would buy the universal and cut strips to place where I contact the bike during cornering.
Anger managment patient
I can't resist. Perhaps the slippery lube on the seat coming from some place else.:eek: Deliverance?
Ok being real. I noticed a huge differance after installing the stomp grip. It really lets me get a solid point between tank and peg. The stuff is so grippy it has forced me to slide back a bit in the saddle. Which I needed because I kinda hump the tank.
That said a sooth seat is very important on a street bike. Otherwise you'll have monkey but in no time. So try slidding back a bit and using the thigh not the groin area as your anchor. The sections near the front are the areas for braking grip. If any thing the stomp will reduce the arm loading of the clip-ons.
Discussion Starter #19
Looking at your picture, it apears that your outside leg isn't in contact with the outside of your tank. In other words, you arent touching the stomp grip...or if you are, just barely.
when cornering, most of you leg is touching the middle (groin area) of the tank.
I have noticed reduced fatigue in my arms since installing the stomp grip, but no help with grip on the bike during cornering.
Your correct only a small area is contacted when cornering but its enough the lock you in from the thigh to the toes. What you can't see clearly is that my mid thigh is gripping the tank. I am also just lifting up to start the drive down the straight.
If you don't like them take them off. All I am offering is advice that might help you get acustom to them.
1 - 20 of 25 Posts
