1 - 2 of 2 Posts
Shell Advance 4T Ultra 10W-40 Synthetic Oil [Liter]
Pricing: $17.50
Shell Advance 4T Ultra 15W-50 Synthetic Oil [Liter]
Pricing: $17.50
Shell Advance 4T with R.C.E. Technology is a unique, fully synthetic lubricant designed to provide Shell’s ultimate engine protection and performance for all kinds of modern bikes. The latest generation of motorcycle engines require premium synthetic oils to maintain the highest standards of protection and performance, whatever the engine size. Shell Advance’s R.C. E.* Technology helps your bike perform to its peak potential, making it responsive to you slightest touch.
*R.C.E. Technology is designed to deliver:
1. Increased oil performance Reliability by helping to remove deposits and maintain oil viscosity to give superior engine protection.
2. Enhanced Control by smoothing clutch engagement and preventing slippage.
3. Enjoyable ride by reducing vibration and damping engine noise.
The technology has been race proven and endorsed by leading motorcycle manufacturers. The product exceeds the requirements of all motorcycle manufacturers.
Performance, Features, & Benefits
• Oil performance Reliability
Fully Synthetic lubricant technology designed to offer ultimate protection and oil performance reliability.
Enhanced cleanliness control: Prevention and removal of sludge and engine deposits.
Ultimate wear against valve train wear.
• Enhanced Control
Increased friction control; optimized friction control for smoother clutch engagement & gear changes.
• Enjoyable Ride
Reduced vibration and engine noise; enhanced shear stability for a quieter and smoother ride.
Specifications, Approvals, & Recommendations
• API: SM
• JASO: MA2
• Shell Advance 4T Ultra exceeds the requirements of all Japanese, European, Indian and Chinese motorcycle manufacturers.
• The product is endorsed by Ducati.
For a full listing of equipment approvals and recommendations, please consult your local Shell Technical Helpdesk.
Main Applications
High-perfomance air and water-cooled four stroke motorcycle engines, including race-tuned and ones with integral gearboxes, and wet clutches.
Motorcycle gearboxes that must be lubricated by engine oils, including some gearboxes present in two stroke bikes and scooters.
* FREE continental USA shipping on orders over $100.
* Outside continental USA, use shipping coupon codes:
GLOBAL250 gets 25% off shipping on orders over $250
GLOBAL500 gets 50% off shipping on orders over $500
GLOBAL750 gets 75% off shipping on orders over $750
* Register on the Motowheels website for Free forum passwords to access discounts on most non sale items or lifetime VIP passwords for the deepest discounts on all items. Look for memberships and choose the membership type that fits you the best
Discussion Starter #2
Ducati Oil Filters and Filter Tools
DUCATI OEM Oil Filter: 1199 / 899 Panigale
Price: $36.45
OEM Replacement oil filter for the Ducati 1199 / 899 Panigale
as low as:
$15.17
5 or more
The original equipment Ducati Oil filter. Fits most Ducati except the Panigale motor
K&N Oil Filter: Ducati
Price: $13.95
Features a 17mm nut affixed onto the end that allows for easy installation and removal. The 17mm nut is crossed-drilled so racers can safety wire the filter to their bike. Fits most Ducati except the Panigale motor
Flo Reusable Oil Filter: Ducati
Price: $119.95
Sale: $109.95 FREE Shipping
Flo reusable oil filters help you reduce waste.
-Anodized aluminum housing looks great and helps dissipate heat.
-Sophisticated bypass system is engineered for greater oil filtration and proper bypass pressures
-Rare earth magnet is attached to the top of the element for pre-filtering the oil.
-Reusable filters made from type 304 stainless steel micronic filter cloth.
-Includes extra seal ring
CORSE DYNAMICS Billet Oil Filter Wrench V2: Ducati OEM Filter
Price: $39.95
CNC machined to ensure exact fitment to the OEM Ducati oil filter.
Secondary fail safe proprietary provision in case of filter stripping: 2 self tapping sheet metal screws to fix the tool to the filter for guaranteed removal (the screws are removable so you don't have to use them, they are just there in case of the worst case scenario)
CORSE DYNAMICS Life Saving Oil Filter Wrench: Ducati OEM Filter
Pricing: $29.95
The bail out tool for an overtighted oil filter.
Corse Dynamics offers an oil filter wrench which works quite well, but we still have customers that insist on using the good ole screwdriver method. If the screw driver hole tears open because the filter is too tight the entire filter falls to pieces leaving the top still connected to the motor. We have heard of failed attempts to remove the rest with: pliers, shears, vice grips, strap wrench, channel locks, or heat typically without any success.
This tool is the solution, it is constructed of aluminum in order to keep the cost affordable, this works but it is not for everyday industrial use. It is designed to get you out of the pinch and save you hours of unnecessary anger and frustration. We have tested this, used this, and are happy with it. We weren’t planning on making them, but it is such a valuable tool for certain situations that we have decided to release it to the public.
* Outside continental USA, use shipping passwords:
1 - 2 of 2 Posts
