Service cost: testastretta VS Mv agusta
1398 Views 5 Replies 0 Participants Last post by  Guest
Is a MV agusta F4 cheaper or more expensive to maintain than a Ducati 4V?
1 - 6 of 6 Posts
Re: Service cost: testastretta VS Mv agusta (El Gladiateur)
its italian. probly a small fortune.
See less See more
the first service is a valve clearance service, but we haven't had to adjust one for a few years. then every 12. schedules are fairly similar, times a little less for majors. although you're supposed to replace a few things at 36,000 that could get really pricey.
it's a 916 with a 4 cyl engine really, with a slight bimota esque 'jam it in' philosophy. not too bad to work on, but annoying at times.
Re: (brad black)
help me out but does the MV use a standard valvetrain or is it something different? i.e. rockers vs. springs
std ujm - shim under bucket, no rocker, valve spring. cam lobes are ground on an angle due to radial valves.
Re: (brad black)
radial valves! that is what i was lost on. thanks brad
See less See more
1 - 6 of 6 Posts
