1 - 3 of 3 Posts
I purchased a Scott's Eyebrow Kit for my 04 RC51, but I do not have the instructions for installation beyond a couple of wiring diagrams. Does anyone have any detailed instructions for installation - I intend to use them as direction signals.
Here's a post from when I installed mine, with wiring diagram. You said you intend to use them as turn signals, using diodes I was able to get them working as markers and turn signals. Check out the video on the post you'll see what I did.
https://www.speedzilla.com/forums/honda-rc51/65150-turn-signal-troubleshooting.html#post661539
When you drill the headlight structure for the eyebrow lights to go in, if you can, hold the assembly so you have to drill going straight up, it reduces plastic debris getting up in the eyebrow area. Otherwise taping a vacuum cleaner hose to a large diameter McDonalds straw will get that area cleaned out.
Also when you test fit the Scotts LED eyebrow lights, you'll see they go in too far. Back in 2011, I made aluminum holders on the lathe that snap into the headlight holes with a tight fit, and then hold the eyebrow lights further back in the headlight. If I had to do it now, I would just print some plastic holders on my 3D printer. Here's a picture of what I'm talking about, hopefully you can come up with something that works for you.
URL for the picture is http://www.airlinebrats.com/rc51/11/110413EyebrowLightMounted.jpg
1 - 3 of 3 Posts
