1 - 12 of 12 Posts
There is a place in Keene, NH that does it. I dont remember their link but if you do a search you should find it. They have an ad in Cycleworld as well.
calculating status...
Yep, Ron at FSS does a good job. I have had quick turn around. Less than ten days actually. Keep in mind that the repair usually f's up the paint. He can paint or powder coat also.
frame straight system does.
He did two of mine. He also removed over a pound from each wheel to balance them without weights. I took off all of the casting nubs, letters, and flash before sending them so that they would be as smooth and light as possible :twocents
What was the cost with Frame Straight? Looks like the best option.
Mine were right around $120 each a couple of years ago. That may be a little pricey for a little dent, but it's the same price if you split a wheel in two, so at least you know what you're going to pay up front.
Thanks, seems reasonable to me, better than buying a new one.
1 - 12 of 12 Posts
