1 - 14 of 14 Posts
i'm looking for recommended air pressures for street and track.
i did a search and didn't turn up anything.
what has worked for you guys?
thanks in advance!
chiromikey said:
34f/35r for street and track.
while the specific bike will matter to some degree as does the riders pace......but there is a huge amount of threads on tires and pilot powers specifically in the RC51 forums...use the search and read away.
Very true (as well as road conditions). FWIW I use 30F/28R to 30F/30R on the track and use 32F/34R on the street. This is for the Power Street tires. The Power Race is a little different. YMMV
if you're referring to the pilot power race tires, they recommend 24R/28F at the track. believe it or not... my buddy had a new set put on and he called the techline just to confirm. just fyi. i was in disbelief but it was true.
maybe different in other states depending on temperature and humidity. so i would consult your local track and tireguy.
I'm curious about something...Am I the only one that thinks he's going crazy because I can't feel a single zippin bit of difference when there's a difference in pressure in my tires?? I've ridden my bike anywhere from 29 to 35 psi in the back and would have been none the wiser if I hadn't seen it on a pressure gauge. I know there's alot more to correct pressure like wear and everything but I just wanted to check and make sure I'm not the only one that can't feel it in the seat of the pants.
for me, i feel a huge difference especially with the front tire. rear is not as noticeable.
1 - 14 of 14 Posts
