I finally got tired of taking my tail section off and switching from high mount to low mount in order to give my girl a ride.
I know, the RC wasn't built for two.... but here we go....
First photo, everything installed.
Second photo, footpegs removed (two bolts per side, takes 5 mins)
Third photo, lower bracket removed from bike (two bolts per side, takes 5 mins)
Fourth photo, lower bracket itself.
The black piece with the holes in it is the bracket for my exhaust and does not change anything regarding installation.
The upper bracket stays under the tail section unless you need to remove it for some reason.
There are several reasons to do this mod. If you never ride two up obviously there is no reason to do it.
1st - The ability to run passenger pegs with high mounts.
2nd - Tail section does not have to be removed to install or remove rear pegs. If you have low mount pipes with aftermarket muffler hangers that eliminate the rear pegs this would also be a nice mod for you.
3rd - My girl loves the new position of the pegs.
Intall is simple and is easy to reverse. The only permanent mod is the removal of the muffler hanger loop from the rear peg bracket which is pretty easy with some basic tools. The rear pegs are swapped side to side, so if you don't cut off the loop it faces forward and gets in the way. It also looks like crap.
