1 - 10 of 10 Posts
· Craft Int Instructor
What Race fuels have you guys ran with good success?? Im running a stock motor with lots of air flow and front Rads and no thermastat. I have a racer friend is trying to get me to run VP C12 or/and Mrxo1. I would think they are both have to high Octane levels.. plus they are both leaded. I was thinking VP U4, U4.2 or U4e.. But looking at Vp's site the C10 looks to be the best choices..:confused:
Yes I know what octane means, and yes I understand running lower octane sometimes produces better hp #'s then higher..
Other info: running Road Atlanta July 3/4 which will be at least 95+ degrees..:eek:
I hav had really good outcomes with U 4.2 on my track bike and sometimes in my RC. My GSXR had a specific map for U4.2 but the RC does no and it ran stronger. I would say get some reflective insulation and insulate ur tank if ur running a really high track temps.
· Nice Member
Not to totally thread jack ya, but I'll be there that day too:eek: Come say Hi, black CBR #77 "I"
Which day Rob? 3 or 4th?? I'll be running "A" with the RC#11 and Neon DUC#501!
I'm running U4.4 and it's a good unleaded pump replacement without having to re map adds a couple HP but seems to accelerate better all the way through and a good price for the addition of oxygen and tetraethyl lead!!!
If you got the money run the new MR12 best fuel by far but you will have to re-map
there is no substitute for leaded fuel on the race track, I thought the "C" series was just high octane which really will be a waste and won't help make HP might as well run pump for half the price!
How long have u been running U4.4? Have you had any problems, are u draining the tank after using it?
· WSMC #51, CVRA #51
+1
Here is some info I wrote on another BBS that may help.
The chemical oxygen in VP race fuels is derived from Methanol. Methanol will attack aluminium and o-rings. Its not enough just to drain your tank, you need to run the oxygenated fuel out of the bike and flush it with pump. Just siphon the race fuel out, add 1-2 gal of fresh pump and ride the bike for a min or two.
The reason for the chemical oxygen is simply to add a more dense air and fuel mixture to combustion chamber. If your fuel already contains 10% of the oxygen needed to burn you can add more fuel and stay at the same A/F ratio. The more air and fuel (some of the air contained in the fuel) you can burn the more power you will make. Thats how oxygenated fuels MAKE power.
Hi-octane fuels alone DO NOT make power. Mater of fact all else being equal you will lose power as you increase the octane. Many bikes make the most HP on pump 91 (unless its an oxygenated fuel). Only if you are running a higher CR then stock do you need higher OC. The reason for this is, 85% of the useful combustion pressures are extracted in the first 30 deg of crank angle. You want fast, complete combustion before the first 30 deg. High OC fuel resists detonation but burns slower. If your not running in to detonation with say 91 OC pump the slower burning 116 OC race fuel will not burn as completely before the first 30 deg. Some of that burn will just go right out the tail pipe as heat loss.
So, only oxygenated fuels will make more power then pump.
Only run as high an OC # as needed for your specific build.
· Nice Member
Both days both days, look for that black 77 cbr and "striders" 01 RC, we'll be pitted together. I think Shane will be there friday early afternoon, I wont be down until 5-6ish.....back to you regularly scheduled th:woot:read
1 - 10 of 10 Posts
