1 - 8 of 8 Posts
The factory manual has you remove the forks to remove the handlebars. Is there a quicker, easier way?
I'm searching right now for past posts but I want to get the Satos done this morning before I run out of time so I'm going about this just a bit backwards.
Thanks in advance,
Mike
Re: Quick help please...installing clip-ons?? (mcoomer)
remove upper on the triple clamps and the clipons will slide off
you do not have to remove the forks
I was hoping that was the case. That means I have to remove the Scotts but that sounds much easier than the wheel and forks.
Thanks man,
Mike
Re: (mcoomer)
Actually, loosening the pich bolts on the forks is much quicker than removing the Scotts.
I did end up removing the forks. After working on the set screw for the Scotts mount for about :30 minutes I gave up and just started from the bottom.
BTW...anyone care to tell me what bar ends they're using with their clip ons? I was hoping to just use the factory ones but they're different screw sizes. I just want something round and black.
Thanks
bar ends
What are bar ends?
Just kidding, I wouldn't use bar ends if I were you. IMO it looks better with out them. I have the Gilles clipons and they just came with little black plugs for the ends of the tubes. I will go take a pic and post it for you.
Modified by APairOfTwins at 8:45 AM 7/28/2005
1 - 8 of 8 Posts
