21 - 37 of 37 Posts
Moderator
Discussion Starter #23
Dry-break couplers (or fittings) have internal valving that do not leak any fluid on disconnect.
As opposed to a quick-disconnect which does.
That is exactly what I'm talking about.
So who has done this?
I've got the Motion Pro quick disconnect on my 51. 5/16 for the main line (the actual line is small, it's just covered in a thick rubber sleeve). I run one of Thorsten's airboxes so I cut the main fuel line 6-8 inches from the throttle body union and plumbed in the quick disconnect. I've also got a 1/4 inch disconnect for the return line but I haven't fitted that one yet. It's been on the bike about a year and no leaks, no issues and totally compatible with pump fuel. I use the single sided dry break with the dry end on the tank side (not much to leak on the throttle body side).
Moderator
Discussion Starter #25
Dude, that's perfect!
Your the second person that uses the motion pro one that said it works fine. Yeah, the single side shut off should work perfect.
So, I'm looking for 5/16.
Thank You
Thank You
If you admit I'm a genius I might even have a spare I could send ya...
I'll look through my spares.
I think the only negative aspect of the MP is hte chance of pinching an o-ring, just have to be careful.
Moderator
Discussion Starter #27
Dude
Your a genius :D
I've used the Quick Coupler PMCD barbed version with the in-line valve on bikes before. Works like a charm. I tried it on the return fuel line on the RC and it leaked. It likely was stressed sideways. I then T-off the return line and and ran a short piece of hose just inside the frame and installed the valved fitting end (female). To drain the tank, I simply insert the male portion of the Quick Coupler into the fitting and drain the tank. The male line has a 2' length of hose attached so it can reach the gas can on the floor. The banjo bolt on the pressure side is till a pain the ass.
thanks for the point into the right direction.... mine should be here in 5working days... will report on completion!
21 - 37 of 37 Posts
