1 - 10 of 10 Posts
Re: Power commander Compatibility (RCcool)
Yes, as long as it has the correct base map loaded for your bike.
Re: Power commander Compatibility (Just Riding Along)
Thanks, I have the answer now, out of curiosity, what is the reason that there are two power commander with different # for RC 00-01 and 02+?
I'm trying to gain a little my knowledge about this kind of stuff.
I don't know the answer to this but I'd check further before using it because there were engine changes between 01 - 02.
The only difference between the early and later model, other than the map that is pre-loaded, is that the ground wire on the later model is longer than the one on the earlier model.
I have just fitted the later 02+ PC3USB to my 01 SP1 with the SP1 euro akra map to start and .... WOW!!
Re: (krisr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krisr »</TD></TR><TR><TD CLASS="quote">I have just fitted the later 02+ PC3USB to my 01 SP1 with the SP1 euro akra map to start and .... WOW!!
Now was that just a WOW???? OR was it a WOOOOOOW!!!
Re: (krisr)
Wow what?
Re: (krisr)
b) Wow I still have my backteeth after cruising now!
works for me
1 - 10 of 10 Posts
