·Guest
I'm about to put on a set of DP pipes, racing ECU, and DP filter kit in my '00 bike. I'm assuming that I'll 'at least' have to tweek the idle speed after all is installed. Is there a single idle screw to tweek or am I going to have to adjust each throttle body while watching a set of vacuum gauges or something? Do ya think I'm going to have to make a run to the dealer to have it dialed in with a Mathesis and if so...........
I'm about due for my 600 mile check-up. Should I get that done and then put my parts in or install everything and then get it down to the dealer for it's check-up and a set-up.
Thanks fellas!
Greg C
Thanks fellas!
Greg C
