I still have a set of steel billet performance cams available.The profile on them is similar to the stage2 Moriwakis,with the same 11.4mm lift.
As some of you may know, the 51 is prone to snapping the cast iron cams when heavier springs are used, its not possible to continue with the std springs with extra lift.These cams are beautifuuly made and are a bargain at US$1125 a set plus shippng,around $65.
Also required are your original cams or just the timimg gears, to keep the cost down the original gears are used.
The Moriwaki valve spring kit is fine with these cams.Any other questions,feel free to send me a pm or email.
I also have a set of Titanium valve buckets,TiN coated available if you are looking at making some serious hp.
Dale
Dale
