1 - 7 of 7 Posts
· Premium Member
Current remaining items 11-16-10:
27MM Offset Triple Clamp (showa sized) with Black anodized upper 500
Ohlins Shock 400
Ride Height Linkage (adjustable and includes heim joints!) 50
Hyper Pro Silver Steering Damper with Gold Mount 250
Woodcraft Rearsets (with both pedals, no damage) 175
Aluminum Monoposto Subframe (from Motowheels, nearly new) 350
Clip Ons (oem) 50
Ducati Performance Rear Sprocket (quick change 40t 525 light!) 100
Sprocket Carrier (oem powdercoated black) 20
Chain (525, like new) 25
Swingarm (no rash, with chain slider, newish bearings) 100
Yellow Fuel Tank (no rust, no bondo, small ding) 150
Fuel Pump and Base (has metal qd fittings!) 125
Side Fairings Hotbodies (not crashed) 100
Fender OEM 749S with white stripe 30
Bellypan Hotbodies (slight pipeburn) 25
ECU 1.6 150
Chip for ECU 748 with pipes (ducati performance) 20
Chip for ECU 916 with pipes (ferracci) 20
Ultimap 853 lofgren adjustable chip 100
Billet Quick Turn Black Fuel Cap (yoydyne, non threaded version) 75
Coils/wires OEM 50
Brembo Iron Full Floating Rotors 200
OEM Air Runners with Pipercross filters (both sides) 75
1997 Frame with Eccentric 100
Full 50mm Termignoni Carbon Fiber Exhaust 1100
Carrozeria Forged Aluminum Black Anodized Wheels 1200
Radiator no leaks pretty straight 80
Oversized Racing Oil Cooler (this thing is serious, with trick hoses) 400
Carbon Breather Box (like new motowheels unit with hoses) 400
Airbox reed valve (needed for corse breather box install) 50
I'm attaching a few pictures for extra sauce.
And the link to the full pictures:
748 Parts pictures by durtb1ker - Photobucket
Email me at jeremyderb at gmail dot com for details.
· Premium Member
Forgot to mention
I also have a set of Tyr Sox with the fleece blanket deals. A few burn marks, but very simple/effective/HOT! $100
Also a set of Medium BT-003R Dot Race tires with 30 laps (one track day, on warmers) 120-70-17 180-55-17 $150
· Premium Member
Desmo do you have a set of stock or aftermarket triples handy to measure the thickness of the material? These are so much beefier than the stock item I can't imagine going another 2mm in diameter would be an issue.
But I am not a scientist ;)
Also in case that sticker is illegible on the photo...that is a CE approval sticker that fell out of a shipment of Ducati accessories. It reads....
"Warning ! Do not remove this label !" (the phrase is listed above in Italian)
1 - 7 of 7 Posts
