Re: (roadkill)
Quote, originally posted by roadkill »</TD></TR><TR><TD CLASS="quote">I never ride with my fingers on the levers. What reduced reaction time?</TD></TR></TABLE>
At 60 mph, you are traveling 88 feet per second. If it takes you only one
tenth of a second to get your fingers off the twist grip and onto the brake lever, you've travelled almost 9 feet. That can be the difference between hitting or missing that van that pulled out in front of you.
Covering your brake lever is a very smart idea on the street. I generally cover mine with two fingers any time I'm in any kind of traffic or confined area where there are hidden dangers. On the open highway, I usually don't bother.
Quote, originally posted by roadkill »</TD></TR><TR><TD CLASS="quote">The pro racers don't ride that way...only extend their fingers when they need to...</TD></TR></TABLE>
That's because they're on the race track. They don't have to worry about things appearing out of nowhere. They brake in the exact same place lap after lap. There's no need to cover the brake lever. (Plus, they need all their fingers on the grips when their bikes can pull power wheelies at over 100mph!)
Quote, originally posted by Manu »</TD></TR><TR><TD CLASS="quote">You only need you index to be resting on the lever. You can also re-adjust your lever so that it is more comfy for you to ride.</TD></TR></TABLE>
If you normally brake with two fingers, it doesn't do much good to cover the lever with only one finger. Of course, if you have true one-finger brakes, then, well... congratulations.
Adjusting the brake lever is a good idea, if you haven't tried that already. When bikes come out of the crate new, they usually have their brake and clutch levers adjusted WAY up in the air. The dealers rarely bother to adjust them down, and I can't believe how many people buy a new bike and never change the position of the levers! I've hopped onto people's bikes who have been riding for quite some time, and found the levers up so high they would only be comfortable if my elbows were below my wrists!
You may also try, when you feel your wrists bothering you, wiggling your fingers around to promote circulation.
