1 - 2 of 2 Posts
For you guys with the Mori (DK) link, Ohlins rear and front forks. What height to do raise up the forks in the triple clamps? I think I followed the instructions that said to use the second line, but the result is a bike that sits up higher in both the front and rear vs. stock suspension, but the front and rear seem perfectly level with each other. I don't have the nose down at all compared to the rear. How many lines to you guys have showing? Two, three, or more?
I am going to experiment with the ride height some and see what I like, but I would like to try what works for others first because that usually saves me time when I look for what I like. Thanks.
Re: Ohlins fork height question (cdrchode)
start with 7 mm showing above the triple clamp and 1 thread showing on the shock. set sag frt at 36 to 38 total and 25 in the rear
1 - 2 of 2 Posts
