1 - 7 of 7 Posts
Does anyone make an OEM style carbon Fiber Mirror ?
Also how much does a set of OEM mirrors cost that are painted Ducati yellow ?
Does anyone sell the OEM mirrors with LED's in them for a turn signal ?
Thanx
Ron
Re: OEM mirror Q's. C/F (998)
There are ducati performance carbon mirrors far around 200
part # 969015aaa & 969016aaa
Fist I assume you looking for a 998. Ducati makes a Carbon fiber mirror but it is not exactly like stock, it has a pivot on the center screw that attaches it to the fairing brace, these mirrors do not extend very far from the fairing (similar to stock) so they are not very usefull. Ducati also has a billet mirror that has a extendable arm and it pivots at the fairing mount and also at the mirror mount. This mirror actual works. All these are readily available from a Ducati dealer, if you have any problems finds them drop me an email.
Re: (Lotabikes)
Yeah i see the ones from DP but i want something like the OEM ones, and these are a little different.
Yes it is for a 998.
Ron, don't totally discount those DP cf mirrors that look a bit different than stock. Did you notice that they're exactly the same shape as the headlights? I've been very pleased with them for years on my 996. But there's a couple requisites: Most important you must be thin in order to see around your torso and under your arms and add 2" round convex mirrors to the outer corner of each mirror. Works for me! The only real drawback is the mirrors surface is a cheap plastic that scratches easily. My
, MH
1 - 7 of 7 Posts
