1 - 17 of 17 Posts
I installed a basic racer harness in my SP2 track bike.
Everything looks ok and powers up, but the fuel pump relay does not close. I can run the low side of the relay coil to ground and the pump starts.
I have tried 2 different bank angle sensors, to no avail.
Is there an anti-theft diode that needs to be jumpered in to enable the fuel pump in the ECU when you eliminate the ignition key switch, with a stock ECU?
I'm trying to load up for the track with my new baby, and she won't start! It ran fine in January, when I brought it home.
I'm about to try wiring the stock harness back in.
thanks.
RC
Discussion Starter #5
thanks guys. This is killin' me.
I have the basic racer wiring diagram. I've done a pin-pin comparison on every wire in it with the SP1 and SP2 wiring diagrams.
I redrew the circuits with the bank angle sensor, bank angle relay and fuel cut relay on the street harnesses and the bank angle sensor and fuel cut relay on the race harness.
The race harness is already wired with no key switch. The kill switch turns all of the power on and off.
The gauges come on. No codes are stored. the FI light goes out. It should run.
The street and race harness both ultimately require pin A8 to go low, controlled by the ECU. It isn't going low. I plugged in the street harness and now it doesn't work either.
I'm about ready to run the bank angle sensor green wire to ground as it is on the street harness. Fuel pump will be always on, when the power is on. Not sure the ECU will like no sgnal at pin 8.
I gotta ride tomorrow!!
PS - stunna I'll get some pictures up. Not in the mood right now...
Discussion Starter #6
OK. I got fuel pump actvation with the stock harness.
Now I get to pull the race harness out and install the stock one, check everything out. Test ride, load up, drive 3 1/2 hours, have a beer and get some sleep.
Hope I don't forget anything important...
WSMC #51, CVRA #51
I removed my bank angle sensor as well. I suspected it was causing me some issues but later found out it was a loose pin in the ECU connector (Pin A8).
Its possible to kill your engine in a crash with out the bank angle sensor.
If Pin A8 is not going low for two seconds after you power the bike on, I would check to make sure both B19 is grounded (side stand/clutch interlock) and B18 (Neutral Safety interlock) with the HRC harness.
What do you mean going low? Are you talking about the voltage?
To bypass the bank angle sensor do you just touch the two out side wires and leave the black with white alone?
WSMC #51, CVRA #51
going low = going to ground. Pin A8 will be Open or have no voltage by it self but rather it pulls a voltage to ground when active. This is ultimately the negative side of the fuel pump relay after it passes through the Bank Angle Sensor. A8 will only go low for 2 seconds after power on then will stay low once the bike is running.
Discussion Starter #14
Damn. It got me!
According to Bob Hayashida, there is a resistor/diode hidden somewhere in the wiring harness that sends something like 9.3V to one of the pins on the stock ECU. No fuel pump without it. It's not on any of the wiring diagrams. An anti-theft thing.
So I got the stock wiring harness all stuffed in - not easy with the cooling system in place. She fired right up. Got all the bodywork on, put my helmet on, dropped it in to 1st and PUH, she died. No sidestand switch.
So I lit the tank, remove the airbox, found the connector, taped the switch in the ON position and pugged it in. In the middle of reinstalling the airbox, my dear sweet wife came in to the garage to talk to me. We had a brief conversation, and I went back to my frenzied assembly, as it was now getting to be about 6:00 PM. Put the airbox on and bodywork and took it for a quick spin around the block. Finally got out of town at 8:30 PM.
to be continued...
Discussion Starter #15
So I got to Chico at about 12:30 and ate a few bites and went to bed.Up at 6 AM for coffee and off to Thunderhill.
Had a few finishing details to take care of, so missed the first session and got the bike tech'd.
Went out for the 2nd session. First track day in 3 years, as my last street ride ended badly. So I took my time and got the feel of the bike. Fantastic motorcycle!! Started picking up a bit of corner speed, remember how to ride THill, squirting hard off the corners. Did I mention what a fantastic motorcycle it is?
About 15 minutes in to the seesion, I'm coming hard off turn 7 and go to upshift and the throttle sticks WFO!!! Holy crap, panic brake, off the track at about 9000 RPM in 3rd gear. Bank angle sensor worked like a champ. As me and my baby were mowing the grass on the north 40, I'm thinking "kill switch, kill switch, damn this grass is slippery, I should have hit the kill switch."
to be continued...
Discussion Starter #16
Fortunately, I was uninjured and didn't take anybody else out.
My first thought after my slip-n-slide was, "Good, the bike didn't tumble." My next thought was, F$^#, I don't get to ride any more today."
I got the bike back on the stand at lunch break and proceded to survey the damage. Nothing major, but crashes are always expensive!
I lifted the tank and removed the lid to the airbox, and there's the rear intake snorkel, sitting upside-down on the throttle body. The very one I was going to screw down when my wife came out to talk to me. So I twisted throttle and stuck the snorkel in sideways and sure enough, It holds it wide-frckin-open.
Sigh...
1 - 17 of 17 Posts
