1 - 5 of 5 Posts
hi all, got an 04 RC51, last running was 2 years ago and ran fine, now it cranks, got spark, pump prime but just won't turn over. any idea?:confused:
Dirty fuel injectors?
calculating status...
When you put your battery back in did you remember the Power Commander ground? I've done that before.
Discussion Starter #4
didn't check injectors , but pc III did light up... but the light is at the very bottom,the very last bar, can't barely see it... does it need to be up?is there a way to turn that up,without connect it to a pc?
Turnning Your Throttle while watching Your Power Commander, You Should see the Lights going up and down as you turn the throttle. ;)
Key on and the engine does not have to be running to see that this happens...
1 - 5 of 5 Posts
