Re: Nitrogen and tires. (Buckelew)
So if I put a big truck tire in my garage and keep it filled with air, it becomes a Buckelew Nitrogen Generator that I can use to fill my bike tires for the track. COOL!
Re: Nitrogen and tires. (Phil 998)
Have anybody tried Helium ?
It will make it lighter. Faster ?
Re: Nitrogen and tires. (johnnymotocros)
Boom!!!!!
I have run it
We carry a bottle of nitrogen in our race trailer. We have back to back tested against compressed air.....no real differance in build up or tire temps. we use the bottle of nitrogen to power air tools if needed. We use a small electic compresser at the track which is hooke up to a small homemade air drying system. we always use that compressor on our race tires so the build up remains consitant. When we get new tires mounted they are purged of the old air an air from our system is put in, we try an shoot for 4-5 pounds of build up front and rear during a 8 lap sprint
Re: Nitrogen and tires. (Shazaam!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shazaam! »</TD></TR><TR><TD CLASS="quote">The problem with using air is that it's a mixture of gases and water vapor.... </TD></TR></TABLE>
Yep, it's the water vapor that's the issue with regular old air, not the oxygen. Which brings to mind the question, why not use dry air instead of dry nitrogen, since dry air is around 80% nitrogen anyways. It may have to do with processing advantages (i.e. cost).
Re: Nitrogen and tires. (JeffKoch)
I for one have never had a set of tires last long enough to have a problem due to the water vapor in the air.
Re: Nitrogen and tires. (Shibbydevil)
I realize that there are technical differences, but isn't all this answering a question that really doesn't exsist? Kinda mental masterbation.
Re: Nitrogen and tires. (Norm)
Quote, originally posted by Norm »</TD></TR><TR><TD CLASS="quote">I realize that there are technical differences, but isn't all this answering a question that really doesn't exsist? Kinda mental masterbation.</TD></TR></TABLE>
lol
Oxygen won't burn, nor will helium. Hydrogen burns good, particularly when mixed with the O2.
I’m all over Marks Nitrogen generator!
Re: (NC Rick)
My friend supplies all the air gas for the Long Beach Grand Prix. Nitrogen is used in racing because of the lack of moisture, the predictable pressure change or lack thereof, and the fact that it will not blow up trackside.
Re: Nitrogen and tires. (STRATUS749)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STRATUS749 »</TD></TR><TR><TD CLASS="quote">Boom!!!!!</TD></TR></TABLE>
That would be HYDROGEN.
Quote, originally posted by Phil 998 »</TD></TR><TR><TD CLASS="quote">All I know is that at the level I ride, I could fill the tires with the gas from my ass (if I could get 31psi) and I couldn't tell the difference.
Exactly my thoughts also.
After 1 kilo of grapes
I think I could raise [raisin] 31 psi
Modified by kell749 at 7:31 PM 6/14/2005
Re: Nitrogen and tires. (kell749)
My friend is convinced that nitrogen is the way to go for his 900ss ie road bike. Personally i check the tyre pressures each time i go out, so i cannot see it would make much difference for road use.
