·Guest
I have entirely too many questions, I know
I need to replace the black fluid that now resides in my clutch resevior. What is the correct procedure to bleed this out with new fluid? Is it the same as bleeding the brakes? Pump, pump, pump, hold and bleed, then repeat?
If it's the same as bleeding brakes, then I don't need a detailed description. But, if it is different, can someone point me in the right direction?
Also, what is the best fluid to use?
Thanks again!
Nick
Thanks again!
Nick
