Brad
Great info, your dyno posts have been a great source that I have used personally in the past. I would however like to point out a descrepency in the info you have posted on the 54/57mm Termi system info based on dyno's of Rob's biike.
The info on Robs bike is not correct. The test, for example with my 57mm installed was done with his standard ECU (asymetrical), not the 57mm or 57mm Corse. The dyno test on the 54mm system was with the correct 54mm ECU. He subsequently borrowed one of my Corse ECU's, which must have worked, because he has asked to buy one from me.
Bottom line is the conclusion that the 54mm system produces more power than the 57mm system on a warmed over 999 is completely incorrect and contrary to previous back to back tests performed.
Modified by steve999 at 11:36 AM 3/5/2005
