I might know a few things about them.....32k miles on it so far.
order your dynojet O2 simulators now. that will rid of the lean condition at low throttle cruise. throttle spring? maybe on the RC8 but not on the superduke.
tip: if you loose more than one reservior's worth of coolant it's time to rebuild the waterpump. unless you like your oil mixed with coolant. any 'wavy' pleats on your oil filter suggests the same.
if you plan to track it get the upper triple clamp and shock extension. otherwise you can get by with pushing the forks about 3-5mm below surface of the top.
if you ride on alot of rough pavement you might consider a fork revalve.
