1 - 20 of 78 Posts
Figured i would start things off with some of my build now that we have a place to put these without upsetting the natives:)
Not sure i have enough room here to post many of the pics so maybe i will leave them off for now unless there is a demand for them.
Bike has taken many changes and i have two and three of alot of parts so if you see them double listed this is why
Customized Gilles triples RC51 fork conversion
Carbonpartz Billet clip-ons with carbon tubes
Carbonpartz Billet clutch slave cylinder
K- factory Billet clutch slave cylinder
Carbonpartz Billet rear race rotor
330mm oversize Wave rotors front
custom one off rear carrozzeria wheel
RC51 carrozzeria front wheel
Carbonpartz custom carbon front endurance fender
Carbonpartz carbon rear hugger
Carbonpartz carbon frame guards
Carbonpartz carbon swingarm cover
Sato rearsets
HRC rearset
Carbon fiber rearsets
Carbonpartz Billet rear master cylinder
ISR Billet rear master cylinder
ISR monobloc front radial calipers
Ohlins 50mm forks with radial mount adapters
ISR Billet front bake and clutch master cylinders
ISR mini rear caliper
Carbonpartz custom 4 pot race Billet caliper
Carbonpartz custom Billet rear race caliper hanger
Thorsten Billet rear race brake hanger
Carbonpartz custom Billet drive pins
Custom rear wheel shim spacer
Thorsten carbon fiber bodywork
Thorsten carbon fairing nose support
Thorsten carbon air box
Thorsten carbon ram air tubes
Thorsten carbon sub frame with built in breather
Thorsten cast HRC type clutch side cover with sight glass
HRC deep magnesium sump
HRC pistons
Moriwaki cams and short port suzuka race heads
Berylium valve seats
Kibblewhite Titanium valves
Keihin flatslide carbs with custom Billet vel stacks or CP custom carbon fiber stacks
Ohlins side mount steering damper
penske shock with titanium spring
Moriwaki Billet RC51 suspension link
HRC ride height adjuster
Moriwaki ride height adjuster
stainless brake lines
Thorsten electrical water pump
HRC rads
custom oil cooler
speedcel battery
Carbonpartz carbon thumb brake
Carbonpartz custom ti kickstand
LED gear indicator
Vapor digital dash
Blue printed motor
HRC CDI (yet to find)]
Full LBH titanium exhaust with Black Dragon custom mufflers
Custom first made Samco rad hose kit
Custom Billet rear wheel axle nut
Custom delrin rear wheel axle nut crash protector
Ohlins fork crash protectors
Frame sliders
tons of ti bolts
COMING: custom swingarm
lots more have to look
Fully sick, thanks for sharing.
Please post more!
Thank you
I will post pics up when i get the bike done of my custom carbon fiber gas tank too :D The bodywork is getting painted silver here as we speak i hope.
I am planning on having a custom swingarm made that allows for better tire width clearance and is 10mm longer like the HRC unit from either billet block wittled down or maybe a greggs custom boxed in and coated, not sure yet. I am leaning towards a GC though TBH and i am hoping it will be not too heavy though
Nice stuff Mark, looking forward to more updates. Thx. :)
Discussion Starter · #20 · (Edited)
Heavy flake silver is now applied:D
Some black and possibly purple going down today or tomorrow and it will be almost done:)
I still have a bunch of other one off goodies and the swingarm to have made but it basically will be done-ish:p enough to drive finally.
I have ordered some ti tubing so i can make a new Y pipe to make the muffler a high mount instead of a low mount.
I have thought about having Gregg make a tube style swingarm and doing some box in but i am not sold on the look and weight. I am now able to machine parts and have taken my 5 year old idea of a billet arm and reinvented it, what do we think of a billet arm?
1 - 20 of 78 Posts
