·Guest
Both clutch and front brake seem to be leaking. Brake more so; it will build up enough to drip down onto the body.
I'm not sure where they are leaking from, both seem to be about the same spot. The fluid builds up just under where the lever attaches to the cylinder. It would make sense if it were leaking from where the little rod goes into the cylinder, but it is hard to tell if that is actually where the problem is.
Any thoughts on this?
