1 - 3 of 3 Posts
I'm getting ready to finish the front end of my XR-R motard.
I've found a CHEAP 4 piston brembo caliper.
http://www.bankeperformance.com/flattrack/brakes.html b1022
And I think a good price on a radial master cylinder
http://www.trianglecycles.com/catal...ctCategoryCode=
I will use this in conjuction with a 320mm R1 rotor.
So here's the question: The guy at the shop said it was a 12mm radial
master cyliner. Is this the right size? It is listed as a Supermoto cylinder
but I thought I would need a 16 or 19mm master cylinder.
Thanks
Mango
Eric Landstrom said:
I'm running a 16x18 Brembo radial master cylinder on that same Brembo 4-pad caliper. It's lacks a little initial bite but offers great feel without any fade. I brake with one finger only and like the set-up.
Try DP pads if you're lacking initial bite. I LOVED em on my SV.
Thanks for the reply.
1 - 3 of 3 Posts
