·Guest
I'm starting to delving into the suspension on my 2000 996 and I'm going to have to change the fork oil soon and am thinking of revalving the front forks while "I'm in there."
I'm deliberating between the 20mm KTECH valve kit or the 20mm Ohlins valve kit; my reading on the KTECH stuff is that it offers more low speed damping, more piston regulation and has a greater range of adjustment over the 20mm Ohlins kit. Has anyone here used KTECH and better yet, have they used KTECH and Ohlins on the same bike?
I will also change the rear shock spring at the same time, not sure if I'll need to revalve though as I'm not sure what the valving on the stock Ohlins rear shock is like and what range of spring rates it can handle.
