1 - 20 of 34 Posts
V4 CyclePath...
Honda's HRC Swingarm is a worthy upgrade for an RC45 and it's an easy
bolt on Mod if you happen to have all the kit parts specified in the
HRC manual... like HRC kit shock... HRC kit suspension linkage... HRC
kit brake hanger and so on... but if you don't have the parts then
it's a pain in the butt to interface one kit part with all the other
stock parts... so it was up to my own skills to engineer and machine a
list of parts to interface the HRC swingarm with the stock Honda
parts... consequently Mr.RC45 has been up on blocks for a couple of
months while the Lathe and Mill turned out the these parts... enjoy
the picture show...
Modified parts along side the stock Honda parts...
7075 T6 aluminum swingarm axle and nut...
7075 T6 aluminum lock nut and socket...
7075 T6 aluminum axle installed...
7075 T6 aluminum nut installed...
V4 CyclePath...
Discussion Starter #2
Aluminum block interfaces stock linkage with HRC swingarm hard
point... titanium hardware...
It took 9 days of sanding and polishing to remove all the rough
casting marks and bring out the luster of the aluminum...
Home made brackets and aircraft Adell clamps now hold a custom ordered
Spieglar steel braided line...
525 DID chain and modified 43t steel Kawasaki sprocket... titanium axle nut and sprocket nuts & bolts...
V4 CyclePath...
Discussion Starter #3
Machining a hanger for a billet 4 pot Brembo caliper...
Finished hanger and torque arm to fit HRC swingarm and home made 7075
T6 7M thread aluminum shoulder bolt...
V4 CyclePath...
Discussion Starter #4
I covered the titanium exhaust with the new titanium warp...
Ohlins shock and 4mm spacer that adjust ride height to correct Honda's
error in trail...
V4 CyclePath...
Discussion Starter #9
V4 CyclePath...
Discussion Starter #10
Now this is cool! I would really hate to see you toss it down the road though..
That's why I'm must check a riders bank account and riding skills before
offering a test hop...
Once bitten twice shy...
Tossin something down the road isn't always a bad thing... makes you feel like hell though. Each time I've tossed a bike... it just came back better :rockon
Did you coat the aluminum in any kind of clearcoat? From my experience raw aluminum will pit very easily if you ride through the wrong stuff. Or you have to keep things really clean (Larry already does this).:notworthy
try Zoop Seal...
looks great larry:rockon
you don't happen to know if the NC30 SSS will bolt up on the RC30 do you? I need one to send to my guy to have made a bit different and i can't get mine off right now so i though using a easily found NC would suffice?
possibly if your old 45 swinger fits my 30 could i borrow yours for a week or so with compensation of course?
Full Spectrum
Beautiful work.
You are crazy to use an aluminium pivot. I dont care who uses them or how much weight they save. Totally not worth the risk.
V4 CyclePath...
Discussion Starter #19
I decided to leave it bare so I could polish it again and again...
V4 CyclePath...
Discussion Starter #20
ok I'll bite..
How much of a RC45 could you fab yourself Larry? Mean how much bike would be needed for you to build one?
I have 5 pages of home made mods... I think it could translate into over
51%... so I would need the other 49%...
1 - 20 of 34 Posts
