it actually is very sophisticated in its simplicity. almost like a manually actuated multi gear centrifugal tranny.
and so has lord douche nozzle. not my fault you couldn't make sense of the technical drawings. it actually is a very simplistic design, and anybody that has ever seen a centrifugal clutch would recognize the design and it's elegant simplicity instantly.look, captain obvious has shown up![]()
if you could get out of your condescending ego's way you would have seen the jest in my postand so has lord douche nozzle. not my fault you couldn't make sense of the technical drawings. it actually is a very simplistic design, and anybody that has ever seen a centrifugal clutch would recognize the design and it's elegant simplicity instantly.
All I have to say is thank God Larry posted simply explaining how the new gearbox is a perfect mesh with the almighty V4 droner. Since Larry could not make heads or tails of the first gearbox drawing he posted one of his well worn plagiarized scans (which he doesn't quite understand either).
Edit: I see that Larry actually used a new scan from the article. Good to see new and innovative ways to inject V4 drivel into every single thread. Make sure you save them Larry to make repetitive inane points in the future.
Good point duc... I'll save them for the next V4 can't have a stacked gear box debate...Make sure you save them Larry to make repetitive inane points in the future.
I thought about that too, but I see a couple of problems with that.what they need to do to make it downshift, is rotate the oposite dogs so they are all pointed in the same direction, that way it could "slip" back into engaugement on the downshift...
I did promise a Oil thread to end all oil threads... I'm installing a digital oilLarry , didn't you promise us a " Springtime oil debate " so you can extoll the benefits of using snowmobile oil in a sportbike or in your case sport-tourer ?![]()
