1 - 5 of 5 Posts
Hey Guys,
Where can I snag some CLEAR Brake Lines, Master Cylinder to the Reservoir?
1st piece I need:
I need for my Brembo Master cylinder, which is smaller then OE lines.... 1/4" ID maybe?
I'd like a piece approx. 12"
Also, My Rear Tube\Reservoir-Combo. mod. (is an OE Master Cylinder, so dimensions are what, 3/8" ID) and maybe 7" to 9" long !;)
Any help where I can Snag some?
Thanks in advance Peps.:)
Peace Jeff
Tygon tubing is what you are after. You can pick it up at McMaster Carr. I also know PJs parts carries it - where I got mine when I bought some Rizoma reservoirs. I have also seen it at Motomummy. Hope that helps somehow.
We sell it also, but it the shipping will probably cost as much as or more than a 12" length. We have the 6 and 8mm versions. If you're using the OEM m/c, you'll want the 8mm.
There are at least 5 different shops in my area alone that stocks Tygon tubing. Any good performance shop should have it.
Discussion Starter #5
Awesome guys,thanks,
Hey nobody,
I normally think engine only thinking about "performance shops" and ofcourse that is my mistake;)
Thanks again guys,
Jeff
1 - 5 of 5 Posts
