1 - 5 of 5 Posts
Spent the last few weeks doing some work on the 02. Hr here 4 there....
Very clean bro! That is one hell of a front end you have started there.
Make sure you use an appropriate adhesive like "sikoflex" to secure that silicon filler block to the bottom of the tank.
Is this 02 going to be for street duty or track? What exhaust will you be running with the new box?
Stunna
Discussion Starter · #5 · (Edited)
Hopefully this one will be good at both. Exhaust yosh low mounts. Thanks for the tip on the seal. The previous owner of this airbox mounted the tank seal to the box. Looks like it will work good in this configuration. Basically at first the 02 was not going to get much work. The body and tank was straight. However the bike had a bent lower, bent clutch, bad front tire... it is slowy being brought back. I put fren tubo brake and clutch lines on. Simon helped out with a tsr slave. Scotts undermount. Dan kyle goodies. Really the only thing left front rotors and forks reworked. Probably brembo rotors and k-tech or ohlins internals. Then done done.
1 - 5 of 5 Posts
